#1011074 07/22/04 10:24 PM
jusr read post "please help no spark" i have a 1995 LS 6cyl contour auto. i took it in for the recall where they replaced all of the harnesses due to the wires being cracked etc. the agency could not start the car when they finished replacing the harnesses due to a bad flywheel.i towed the car home and replaced the flywheel, tried to start it but there is no spark. i replaced the ignition control module, still no spark. on this model which is the wire that supplies power to the coil and which fuzes should i check. where is the test plug located and which pins do i jumper in order to pull the codes. thanks, john
#1011075 07/22/04 10:52 PM
You drove the car in, but had to tow it away? This fix should absolutely be on them, if that's the case.
#1011076 07/22/04 11:08 PM
probe the green wire with a purple stripe to see if you have switched power to it. Its on the coil pack.
#1011077 07/22/04 11:09 PM
sorry, i forgot to mention that the car was towed in to the dealer because it was blowing fuzes due to the harness problem.
#1011078 07/22/04 11:14 PM
i will have to wait until tomorrow to check the green and purple stripe wire as it just started to rain.
#1011079 08/21/04 06:17 PM
i checked for power on all four wires that go to the coil with the key on but no power. in the hanes repair it showes a diagram of a 4 cyl and the wire goes to fuze #4 i checked fuze #4 and there is power there. the green wire with purple stripe has no power. on this 6 cyl. which fuze sends power to the coil? thanks john.
