Page 2 of 2 1 2
#1010983 07/23/04 03:38 PM
OK I don't want to hijack but since the discussion has turned to transmissions ... could a bad throw out bearing cause a stiff, squeaky clutch pedal and a loud rattle when the clutch is released in neutral?
#1010984 07/23/04 09:24 PM
Originally posted by todras:
Why aren't you guys telling hime to upgrade the tranny at the same time? Saves a lot of $ to do it once and do it right. At minimum an LSD should be installed. Also third gear synchro is most likely a little more worn than the others so that should be replaced. New throw out berring also.
Umm look a few posts up Todd I said that already
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#1010985 07/23/04 11:47 PM
9
9
thanks for the info guys, i just got my car about 4 months ago and as far as i can see it's in really good shape. it only has 36,000 miles on it now and its a 98. im just worried mainly about the trans because i know it already shifts hard into second now and i just don't want to break nothing as soon as i get the turbo installed . im planning on getting a stage 2 or 3 clutch intalled and an LSD+ a lightweight flywheel, new motor mounts and a european handaling kit to start+ exahust. after doing research i think that should be enough to last for a good while untill im ready to go all out with it and make 400+hp (after im done with school). but again im glad u guys could give me the more experienced look that i needed. thanks again
98 contour Svt Silver frost "life is a game so make a move" Jermail T Hayes
#1010986 07/24/04 11:16 AM
W
W
You have pre-00 pistons. If you go over 6-7 psi you may break the ring lands.
I'm thinking take yourself to the 3L conversion forum. If you haven't had a turbo car before you will be more than happy with a 3L contour. You can learn a lot more about the car and engine and you can make that car compete with any late model v6 sedan on the market right now. Afterwards you can upgrade that motor to a turbo if you still find you want more power and want to keep the car. Take it in steps and you will get more use out of the car, learn more and probably enjoy it more.
#1010987 07/24/04 01:28 PM
The one time I had a throw out bearing it would make a whirring sound when I'd let the clutch out and it was in nuetral. So yes, that sounds like a throw out bearing going bad. Don't know about the squeaky clutch though.
#1010988 07/29/04 02:56 PM
I
I
def. start with suspension or the turbo will rip your cars guts out
-the original non contour owner- an m3 or an sti? thats like asking "Miss USA or Hooter's waitress?" 05' Sti Silver/Silver
#1010989 08/04/04 02:20 AM
9
9
well after looking arond i have decided to just go with the 3.0 conversion b/c of the money. plus i think i would get more fun out of my car by going in steps. i was going to do it anyways so i guess i should just get it out the way huh. but thanks again for all the help guys.
#1010990 08/04/04 06:51 AM
W
W
No problem. Good luck.
#1010991 08/04/04 07:16 PM
Check out Buckshot Motorsports for all of your 3L needs!!!
CSVT E0 3L 14.5 @ 94mph, Stock Intake, Stock Exhaust minus Resonator, CEL, And Broken Pass. Side CV...Untuned.
Page 2 of 2 1 2
