Just to anwser your questions, (welcome to CEG btw) The hood, won't fit, the front bumper doesn't fit, and the fenders don't either. When ford brought the mondeo over to be the contour they made slight changes in order to I guess fit our taste, or just be asses not sure.. The corner lights on the mondeo are more pointed, while the contour's are more blunt. The grille lines are different then that of a contour, so the hoods wouldn't line up. Now right behind your corner lights, the bumper goes up a little tiny bit. I believe someone said 1/4 inch. While ares goes up about 1/2 to 3/4 of an inch. Your head lights are also shorter in length then ours, making the grille area larger. Hope any of this helps.
