Posts: 17 |
Im hooking up an amp. Where's the best place to feed my power cable from the passenger compartment into the engine compartment? Thanks in advance.
Posts: 64 |
I ran mine through the existing hole under the dash on the driver side. It can be seen if you look at the inside wall above the brake about a foot. It's a rubber "punch through" that leads to the engine. Good Luck!
"I don't claim to know everything... Just more than you."
Posts: 536 |
Theres a rubber insert in the top righ corner of the engine compartment that already has one wire going through it, you should be able to fit the wire through easily..
Brian 1999 Contour SVT Green KKM, Dual 40 Series Flowmasters, SHO Shop Y Pipe, Removed Resonator, B&M Edge Shifter, Stainless Grills, Painted Rear Reflector, Green Underbody Neons, JSP Grand Touring Spoiler, Eibach Suspension, 18" Katana Tezzas, Pirelli Rubber, Graphics by http://www.clubconceptz.com brian8064@hotmail.com
Posts: 17 |
holy crap! what a chore. theres a thick black wire tube going what looks to be into the passenger compartment. Do I cut that open and thread the power cord through there, or can I slip it next to that black tube? It seems that the opening is juust big enough for the tube that's allready going through it. Plus, there's an electrical box right in the way in the engine compartment. Is there any way to remove this huge obstruction temporarily?
Posts: 17 |
btw, can anyone send me a schematic of where this hole is?
Posts: 536 |
You should be looking on the drivers side..Yes there is a thick tube going through there but it will still fit you can always attach the wire to a hanger and shove it through there thats how I did it...or you can always drill a hole just be carefull not to hit anything..
Posts: 8,142 |
Posts: 3,567 |
when I ran the power wire to my amp I drilled a 3/8 hole in the air duct that goes around the cabin air filter and then just put the wire under the filter and bent the filter around the wire, it was real easy and took longer to take the wiper arm off to open the panel to access the filter.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 17 |
Thanks to all who helped. It was simple enough once I knew what I was looking for. Now to just crimp this damn power cable...
