Page 1 of 3 1 2 3
#1010072 07/21/04 11:11 PM
ok.. i baught a oem cf hood from livinsvt..... it is a nice hood, lines up nice and everything, but i cannot get it to latch down... do i have to modify the hood latch if so.. what do i need to do???
also, the plastic around the HVAC.. does that just pop out, i have the white overlays, but im afraid to pull too hard and crack the plastic or whatever?? thanks a lot for the help!!
#1010073 07/21/04 11:31 PM
V
V
First, let the hood-latch "catch" on the lock. Then, with your palm directly over where the latch is, shove that summbitch down hard.
-Chuck Dienzo Black 98.5 E1 SVT #5022 of 6535 Born on March 16, 1998 "If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
#1010074 07/22/04 12:00 AM
A better way to do it to, is to apply firm and steady pressure like your give some one CPR...let the latch catch, and then do that.
Lupe
#1010075 07/22/04 12:12 AM
hood pins?
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#1010076 07/22/04 12:16 AM
Originally posted by KingpinSVT:
hood pins?
just thinking that....
Lupe
#1010077 07/22/04 12:21 AM
hood pins?
what he said
Formaly FLCEGkid Chris Bertrand 1995 Ford Contour Gl 2.5 V6 MTX FOR SALE! Somebody please buy my Fiberglas hood!!
#1010078 07/22/04 12:26 AM
the thing is though, it isnt even catching the latch....the latch is like 1/2 inch forward toward the front of the hood, and it doesnt really look like it is even hitting the latch
#1010079 07/22/04 12:31 AM
The small bolts on each side of the hood, that hold the hood to the car, losen them...you can actualy do slight adjustments with them lose...but it takes 2 people to do....i found this out when i put a fiberglass hood on.....it was off center....i losten the bolts that connect the hood, and moved it down slightly...and it fit perfectly.
Lupe
#1010080 07/22/04 01:47 AM
I have not seen the fitment of the livinsvt hood, but with the previous OEM CF hood, buyers had to remove the hood latch and dremel the holes (not the latch itself) to move the hood latch up so it catches the hood.
Go with Roz's suggestion and try loosening it first. If that doesn't work, you'll have to remove it, dremel and fit.
HTH
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#1010081 07/22/04 04:39 AM
Loosen the bolts and move the hood so it will latch, also move the latch (doesn't move much, but it helps to move it). You should also turn the hood bump stops all the way down and maybe even cut them some. Then it's not gonna line up perfect with the fenders, loosen the fenders and move them.
Page 1 of 3 1 2 3
