Page 2 of 4 1 2 3 4
#1009922 07/27/04 07:31 PM
Ok the saga continues. The car would start so I had it towed to the dealer (stealer?). I need a new timing belt, pulley and water pump as well as a crank seal. Bottom line - 1100$. Ouch. I actually thought it would be more.
So we shall see. Thanks for all the great advice....
TD
99 Blue Contour Automatic
#1009923 07/27/04 07:55 PM
This IS THE VCT RIGHT because i think mine is gone too. Havent had the chance to get the codes pulled or test the resistance.
Forgive me for size and arrows but i want it do be noticable
#1009924 07/27/04 11:16 PM
Yessir thats it - test the resistance. Read the earlier posts for the correct restitance in ohms. Good luck
PS What a clean engine. Some one has been busy. TD
#1009925 07/28/04 04:52 AM
Out of curiosity why does the Haynes Repair Manual for contours (95-2000) not display the VCT engine VCT solenoid.
There is nothing that i can find on the VCt i know i now know were it is and now its function. But why isnt it in the manual. Oh and the VCT solenoid costs $27.72 i asked the dealer. Not 600 or some-odd.
#1009926 07/28/04 02:05 PM
Originally posted by p3dr02:
...Oh and the VCT solenoid costs $27.72 i asked the dealer. Not 600 or some-odd.
Well on NVS and my part i can tell you that that's what they charge up here in Canada for the VCT
- Eric previous: '98 contour sport zetec mtx light prairie tan
#1009927 07/28/04 04:05 PM
well bull i will call once more to a ford dealer i will repost their exact word on pricing. oh here is a little info guide and some ways of testing
http://www.asashop.org/autoinc/july2002/techtips.cfm
#1009928 07/28/04 09:30 PM
F
F
Got to ask, my 98 CD manual is calling the "oil feed sensor electrical connector". I found under removing the valve cover?
I',ll keep digging though!
Underneath valve the cover is the soleniod that controls the pressurized oil flow to the VCT. Looks like taking off the valve cover you should see this solenoid. solenoid resistance 3.0 to 6.0 ohms.
Disconnect the VCT solenoid valve harness connector.
l Key on.
l Measure VCT circuit voltage at the VCT solenoid valve harness connector.
l Key off.
l Was the voltage reading greater than 10.5 volts?ยต 1. Disconnect the oil feed sensor electrical connector.
One other test basically each pin to soleniod case (I'd assume to ground/head or what ever to ground.)
fuse F-9 feeds this (once the PCM relay is energized) and Idle speed control valve and something else that was not the this screen.
I'll continue looking the procedure if is it's listed?
Paul
Diagnostic Trouble Code (DTC) P1380 indicates a short or open exists in the VCT Solenoid valve circuit. P1380 is a KOEO, KOER DTC, Continuous Memory DTC P1380 will illuminate the Malfunction Indicator Lamp (MIL).
Possible causes:
-- Open or shorted circuit.
-- Damaged PCM.
-- Damaged VCT solenoid valve.
l Scan Tool connected.
l Start engine and bring up to operating temperature.
l Check for DTC P1380 in KOEO or KOER Self-Test.
l Key off.
Paul 98 Mystique LS 2ea (07/97)(08/98)
#1009929 07/29/04 03:11 AM
Yeah, just changed mine last week.
'98 Mystique (Zetec - ATX) 430,000 km !!
#1009930 07/29/04 10:44 PM
CEG road warrior
CEG road warrior
Where? I just called a dealer and they wanted $291!
#1009931 07/31/04 02:23 AM
Locoz i called NorthSide Ford I live in San Antonio texas their number is
Northside Ford
9800 San Pedro
San Antonio, TX 78216
Phone: (210) 525-9800
or Toll Free: (800) 525-9810
REmember i asked for Vct solenoid and thats what i they told me the price was i asked twice bcause i didnt believe them since i had read the forums and some said 500- 600
Page 2 of 4 1 2 3 4
