#1009504 07/21/04 07:55 AM
mkrog Offline OP
My wife's 95 v6 has started to run hot,after about 20 miles on the freeway the temp gauge is at the L on the gauge.Sun day I replaced the thermostat with a 180,checked the water pump and flushed the system,still runs hotter then it should.THe fans come on when the temp. reaches the L on the gauge,also runs on A/C and deforst.Any Ideas,are the fans coming on to late?
#1009505 07/21/04 12:56 PM
H
H
Where did it used to run about?
#1009506 07/21/04 02:19 PM
thermostat may be stuck closed
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1009507 07/21/04 02:42 PM
mkrog Offline OP
used to run at the low side of the M,thermostate is open.I wonder if the temp gauge sending unit is bad.Just got back from the rad.shop they used a gun with a laser and showed the water temp.to be 185and 193 and the gauge at the A.
#1009508 07/21/04 03:03 PM
If all else fails, have a cooling system pressure test done.
1998 Contour SE 2.5L Duratec DOHC 5spd. "Who needs a working IMRC? - I don't." 1968 Chevelle 300 Deluxe 1994 GMC Yukon SLE 1972 Plymouth Roadrunner - restoring for a friend.
#1009509 09/15/04 09:29 PM
Krog - did you ever find out the root cause on this? Im having the exact same issue and am about to replace the ECT sensor, but could be the sending unit. Thanks...
1998 Black CSVT, 75k mi
