#1009451 07/21/04 03:50 AM
W
W
Hi, still new but learning.
Read this post
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=651278&page=&view=&sb=5&o=&fpart=1&vc=1
In which overton had his problems and I thought
I had located mine down to the back of the switches on the
dash panel. Furthering the conversation of the wires if I run
a jumper from purple/blue wire to the purple wire and the
blower works. So I replaced the switch and it worked for a
couple of days and now nothing again. Same problem, if I run
a jumper the blower works fine This is really starting to
piss me off. Please help.
Thanks in advance.
most likely your blower resistor pack, check it out and replace if need be, its under the dash, passenger side, near the blower itself
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
