#1009396 07/21/04 01:46 AM
minger Offline OP
I finally got around to seeing why my key does not unlock the driver's door from out side (97 Tour with power locks, no remote entry, manual windows). I thought the lock cyclinder was shot cuz the key goes in fine but will not rotate. It used to work if I jiggled the key so I think/thought the lock was the problem. I followed the Hayes manual and went removed the door panel fine and then tried to unbolt the two bolts to remove the bezel. First bolt was fine, then the head of the next bolt just snapped off. I did not over do it, it simply snapped. ARGH!!! Now the bezel won't come off and without that, can't remove the lock. What do I do now? Drill it out? Tips?
Another related question:I don't think it is the lock cylinder. When I loosened the three screws holding the thing that clamps to the B pillar when the door is closed (sorry can't think of its name) the keys twists fine, when the "thing" is tighten, no luck. Loosened, back working. Any idea what is amiss or out of alignment or something. Thanks...
#1009397 07/21/04 04:44 AM
Door get slammed hard one day? Been in a wreck?
#1009398 07/21/04 06:38 AM
Ahh, i finally found this problem out....
When you remove the 2 bolts (or 1 and other snapped off) and it wont come off, get a flat head screw driver that fits into the hole (not resting on the threads0 get a Hammer, and hit it a few times out, then get a file when its out, and file the rust down
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#1009399 07/23/04 02:23 AM
minger Offline OP
No wreck. Not a big door slammer.
The problem started once in a while and slowly became more frequent. Hmmmm, I guess I'll just have to fidde with it one day.
