Ok, I just got a new head unit. I wired up the harness, went and pulled out my old deck. Then I went to bypass the factory amp. Well that was were the trouble started, One connector on the amp bypass cable fit fine, but the other was completely wrong. So I left the deck out, and went back to where I got the Harness. I noticed that I had no Clock, and my keyless entry didn't work now.
I got to the store and they say that is the only one they carry and I will have to run new wiring to the bypass the amp.
I was kinda mad at this point since i bought a harness set that said on the package "Easy to Use. No Splicing!" I came home and set up the wiring for the bypass. I ran wire from the harness on the deck, to where the speakers plug into the amp. Then I put the new deck in.
Tunred on the car, and had no power to the head Unit, or clock, and my keyless entry still won't work!
What did I do wrong? Should I remove the battery cable to see if it resets something? I have done HU installs before, never had a problem, but now this is driving me crazy.
Edit- I checked for blown fuses. I didn't see any.
