#1008763 07/20/04 12:44 PM
golgo13 Offline OP
My idle is low and rough but also when I am driving the car seems to be getting a stuble like its gasping for air or fuel. Now I have clean the iac valve,egr valve,tb,change fuel filter, spark plug and wires,trans oil and motor oil.
Oh and I have no light on and get no code. Now would a bad egr valve or fuel pump give me a code.
#1008764 07/20/04 01:40 PM
F
F
EGR is disabled at idle. A bad fuel pump shows up a WOT and under a 1/4 tank. I doubt neither is your problem. I suggest cleaning MAF & IAC for starters.
96 Sport 2.0L - 190,XXX miles
#1008765 07/20/04 03:52 PM
I haven't searched yet but does anyone have any instructions on how to clean the IAC?
Thanks,
Jon
#1008766 07/20/04 10:54 PM
golgo13 Offline OP
I have clean the MAF and nothing but i can't seem to locate the IAC. I was also thinking the solenoid or the thottle position sensor.
#1008767 07/20/04 11:31 PM
Z
Z
Have you checked for a vacuum leak?
1997 Mondeo Ghia 2.0 ATX
#1008768 07/21/04 11:44 AM
golgo13 Offline OP
no vacuum leak but the problem is getting worst to were it seem like the engine is going to fall off the car.
#1008769 07/23/04 05:26 PM
golgo13 Offline OP
now the engine is slams down when it shift on first gear some one please help by the look of it the engine might fall off.
#1008770 07/25/04 02:30 AM
golgo13 Offline OP
anyone
#1008771 07/25/04 05:02 AM
Your engine slam shift is probably more of a bang shift. I donâ??t know if you have heard, but the CD4E ATX transmission has a bad shift sensor. And you need to replace it. Donâ??t worry, its extremely easy to do, all you have to do is take off the driver side wheel, and you will see a circular/cylinder shaped thinger with a wire attached to it in your transmission, pull power from the battery, and get some pliers and a screwdriver and take out the old sensor, its OK if you break it because... Letâ??s face it; you probably never will use it again. The new shift sensor should just slide in that same hole, Reconnect everything, put the wheel back on and TA-DA! Clean shifts again, you will notice that it shifts at higher RPM's but thatâ??s normal, its better then leaving the old sensor in and destroying your transmission anyways.
Your main problem is listed in the FAQ. The sound of rushing air and power loss can be found here
You will notice that on ALL 1995 Contour's equipped with the V6 have had a Recall for your problem, so it should cost your NOTHING to have it fixed.
And as for you bang shift problem I donâ??t think there is anything listed in the FAQ for it (though there should be something there, since itâ??s an extremely common problem). But post a message in the transaxle forum, tell them that you have a "bang shift" going on, and ask for the part number for the new shift sensor. Even if you donâ??t have a bang shift, or itâ??s not that apparent, you should do it anyways because long term abuse will result in later transmission problems. I am assuming you have the ATX transmission because you talk about how IT shifts, and not you. I hope this was as of some help to you, even if I was wrong about one of the problems, I still helped somewhat with it.
#1008772 07/25/04 03:37 PM
By the way, it usualy helps to tell us the year, model, and submodel and transaxel you have before you tell the problem. Each year has its own little quirks and recalls. It gives us a good place to start.
