I just got competent at changing front brake pads on my 2000 SVT (used the contour.org how to). This opens up the possibility of switching front pads from street pads (like Bendix Titaniums) to track pads (like Mintex 1144s)when getting ready for a track day weekend. Does this create problems by using different compounds on the same rotor? Any other plusses and minuses? Anybody have personal experience with this? Thanks.
Sometimes is does and sometimes it doesn't. It mostly depends on the condition of the rotor. The closer to pristine the rotor surface is the less difficulty in switching.
Most likely you will just need to bed in the swapped pads and you will be OK.
Ideally you'd want to have a set of rotors to keep with each pad compound, so you won't have to re-bed them each time. The pad compound gets embedded in the surface of the rotor, and that's what causes the brakes to work. So if you swap pads to the same rotors, technically you really should re-bed them and let them cool to ambient before using them on the track.
Pacific Green '96 Contour LX V6 â??98 GTP, light mods, 14.66/94 Calypso Green '92 Mustang LX coupe, 13.56/101 Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion KCR SCCA 2002 Solo II Street Modified Champion
I just keep my 1144's on all the time. The extra wear you'll get likely won't be alot more compared to changing pads and getting them "reacquainted" with the rotors each time.
Regards, Alan
03 Volvo S60 2.5T AWD 98 Mystique 2.5 MTX 99 SVT - Inheriting Lil Monster's parts 98 SVT - Lil Monster (RIP) 183.7 whp Quaife/Fidanza/UR UD Clutch AFE/MSDS/SHO-Y/Bassani/MagnaCore GC/Koni/22mmR/EndLinks/ES/ KVR Slotted/1144's/SS Lines/MASItaly
Moderated by  Andy W._dup1
