E
E
I thought i would ask before i try.
Has anyone tried this?
I saw those headlamps a while back on a red Contour made out of fiberglass (THE ONE WITH THE MIRKO LIP)
I've worked with fiberglass before on my old festiva's rocker pannel but i have never done what i'm going to try.
I want to take a CAST of the rear of a STOCK 95 headlamp assembly and then line the casting with fiberglass then sink in pair of OPTILUX Halo Beams then finish it off with fiberglass.
Any problems you can think of that i may experience?
Or maby another way of doing it?
Thanks
Eddie
1995 Mystique, 2.5 V6, MTX, 2.5 inch Exhaust tubing, Vibrant Highflow CAT, Vibrant 2.5 Resonator, Magnaflow Muffler, SVT cams, Ebay Intake *YAWN*, HELLA 550's. FINAL LAP Is my New Best Friend!
never know till you try
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
You'll need to use fiberglass matting & resin...not the stuff that comes in a can like bondo. Also you'll need to make provisions for levelling the lamps. I'm not real clear on how you were going to accomplish this project, but that's all I can offer
1999 Sportage 4x4...don't go there, it was free ....______o_o .../_l l__\____\ ..|--l l__----[]\|/[] .....................oo =( )_)----( )_)--)_)
E
E
ya i knew about the matte and resin but i heard of a fiberglass product call KITTY HAIR they use it in small areas to create shapes and so on.
I plan on making a mount out of lexan so the lamps themselves can be aimed or repaced if nessesary then covering the whole peice with a moulded peice of lexan to match the contour of the lamp and make it flush with the front body line.
The picture in my head seems to work, now just the practical application is needed.
Thanks
If it works.....I know yer gonna make some money off it!!!! Well, at least I'M WILLING TO PAY!!!!!!!!!
Eddie
00SEMTXMeshgrill,KKM&K&N,Fogsmodded,17"MotegiFF5's,SilverELgauges,BlueLEDinterior,Knaubered Trubendzw/magnaflowhttp://www.sl33stak.com FSVT Smart pump
E
E
I ran across this on a different forum I am on. Perhaps it could be helpful to you?
http://www.reproduce100s.com/
And, just keep in mind, one of the factory aimers are right in the center of the pre-98 lamp. Its possible to have your highbeam socket where the stock piece is, but it might make you run a really small lamp. Of course, that is only if you plan on using the OEM aimers. If you use a different lamp, like the 90mm units from Hella, they have thier own aimers and it could make your job slightly easier.
Something tells me that your are somewhat going after the look that is on my car.
· Jon Miconi · Coming Soon! · 01 Cougar · 98 V70R
E
E
wow thats such a good site.
thats exatly how i want to do it.
Thanks a bunch.
