#1003953 07/14/04 06:09 PM
dan6515 Offline OP
I received this advice:
Two things
1) temperaure sender -to the gauge
2) temerature sensor -to the ECU
Both are located by the thermostat housing. #1 seems to be a common problem - test it , replace it , Ford part , DIY easy all will be well......while your in there 180* thermostat. And all will be even better!
95 Mystique MTX - not stock
--------- Both Zetecs
'97 Contour Mtx - stock -
.......but now I would like to know what the temperature of the stock thermostat is. I have a '98 Contour LX with a 4 cylinder Zetec.
This website has been a great help for me but definitely falls under the category of "The more I learn the less I know".
Thank you for all your help and advice.
-Dan
#1003954 07/14/04 07:22 PM
IIRC stock tstat is 195.
#1003955 07/15/04 05:30 PM
dan6515 Offline OP
Here I go again...what does "IIRC" stand for?
Thanks,
Dan
#1003956 07/15/04 08:17 PM
If I Remember Correctly
#1003957 07/15/04 10:48 PM
dan6515 Offline OP
Thank you...
#1003958 07/18/04 01:04 AM
W
W
You do.......
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
