Ok, so after I replaced my Alternator my Car finally stopped Dying. But even before that I noticed that my pulley's would squeal when at highher RPM's right at up shift. I found the problem to be a bad tensioner. I had no money at the time so I just kept it that way thinking that it was a nusence and not a potential problem. When 1 1/2 years later I have the same thing happen, but this time I noticed that when it squeaked and the light came on, it did not go off. I found that only when I was almost to or idling that it would finally go out. I then decided that it was fianlly time to change the tensioner. So today I changed the tensioner thinking that would solve the problem. Well, after testing, the light still came on. I reset the computer (disconnecting the battery for 10 min) and thought might also be what it needed. Well after restarting, it still did this. After test driving, I found that the squealing had stopped, but that when that ligt is on, my dash and headlights would dim, indicating that the alternator had stopped charging. I am stumped with this problem paticularlly beacuse I had a charging system test dome and the Alternator AND battery came back good. If anyone has any ideas on what could be the problem, I would very much appreciate a responce back. Thank you and have a good day.
