If you are not sure if you have disc or drum I can confidently predict that you have never bled your brake system. Air in the lines is one of the more likely possible causes for your symptoms.
Brake fluid needs to be replaced once a year minimum for optimal performance (firm predictable pedal). Brake fluid deteriorates over time, absorbing moisture and collecting gas bubbles, causing inconsistent brake performance and brake part corrosion.
Bleeding brakes is dead simple if you understand the technique and have access to tools â?? otherwise, take it to a brake shop and make sure they do both front and rear.
This is a simple maintenance procedure that you should do regularly anyway - it may also be the solution to your problem.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
