Here's all the fuse info from the 1998 owner's manual.
Engine compartment fuse box:
1. Main power supply to vehicle electrical system - 80A
2. Engine cooling fan - 60A
3. ABS braking system, heater blower - 60A
4. Ignition and EEC module - 20A
5. Foglamp - 15A
6. not used
7. ABS system - 20A
8. not used
9. Electronic Engine Control (EEC) - 20A
10. Ignition switch - 20A
11. EEC Ignition module (memory) - 3A
12. Horn and hazard flasher warning system - 15A
13. HEGO sensor - 20A
14. Electrically operated fuel pump - 15A
15. Low beam headlamp (passenger's side) - 10A
16. Low beam headlamp (driver's side) - 10A
17. High beam headlamp (passenger's side) - 10A
18. High beam headlamp (driver's side) - 10A
R1. Daytime running lights
R2. Radiator fan relay (high speed)
R3. Air conditioning
R4. Air conditioning clutch relay
R5. Radiator fan relay (low speed)
R6. Starter solenoid
R7. Horn
R8. Electrically operated fuel pump
R9. Low beam headlamps
R10. High beam headlamps
R11. EEC module
D1. Reverse voltage protection
Passenger compartment fuse box:
19. not used
20. Wiper motors - 10A circuit breaker
21. Power windows - 40A
22. ABS module - 7.5A
23. Backup lamps - 15A
24. Brake lamps - 15A
25. Door locks - 20A
26. Main light - 7.5A
27. Cigar lighter - 15A
28. Electric seats - 30A
29. Rear window defrost - 30A
30. Engine Management system - 7.5A
31. Instrument panel illumination - 7.5A
32. Radio - 7.5A
33. Parking lamps (driver's side) - 7.5A
34. Interior lighting/electric mirror adjustment/clock - 7.5A
35. Parking lamps (passenger's side) - 7.5A
36. Air bag - 10A
37. Heater blower motor - 30A
38. not used
R12. Interior lighting
R13. Rear window defrost
R14. Heater blower motor
R15. Wiper motor
R16. Ignition
D2. Reverse voltage protection
