I tried to search, but no luck. I've got a 2000 SVT with 215/45ZR 17 Potenza S-03 Pole Positions on 17 inch wheels. The stock wheels were recommended to be run at 32psi according to the sticker inside the door. What should I run the 17's at? Thanks.
2000 SVT Black #1400 of 2150 2020 miles as of 6-25-2006
I run mine around 35.
For my S03's i run 35psi, of course, I have 225/45's. . .on 7.5.
Atleast 35psi. I prefer a slightly stiffer ride though and sometimes run mine at 37-38 front and 36psi rear. Though I don't think its optimal for tire wear so I usually go for 35psi.
H
H
i do similar. about 39 in front and 36 in rear. i havent noticed any kind of excess tire wear.
I haven't put the Neo Gens on yet, but I noticed they say max 50 psi I usually keep mine around 32ish though.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
H
H
the max readings are usually meant at operating temp. add a few psi to the cold psi reading u put in. some say the tire adds 5-10psi at operating temp. others say they havent noticed any difference. i dont think filling to 50psi cold temp is a good idea.
I just mentioned that because every other tire I have had said in the area of 40 psi. I was surprised that these said 50, although i have no plans on going that high.
W
W
High performance tires are usually 44-50psi max cold.
I set mine in the 38-40 range front and 36-38 range rear. It keeps the sidewalls nice and stiff for cornering and is well within the tires range.
Close to mine. I run 40psi up front and 35psi in the back on 225/40/17 Kumho Ecsta ASX's.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
Moderated by  1314_dup1
