#996047 07/04/04 04:24 PM
9
9
My transmission is shifting really hard. Whenever you release the clutch, the whole car lurches really bad. Could it be that i just need a new clutch, or could the transmission be bad. Also, i can hear a sound coming from the transmission, it sounds like something is flying around inside the transmission. Anyone have any ideas what the problem might be?
I Finally Found Myself, Thats Why I'm Not Here! Pics of my Car
#996048 07/04/04 09:38 PM
Z
Z
bats in your bellhousing?
2000 csvt #1553 Black/Tan
#996049 07/04/04 09:50 PM
sounds like you arent releaseing the clutch properly. Usualy on a cold start you have to be a little more careful with letting the clutch catch to make it a smooth ride. Just let the clutch out a little slow, as for another thing, dont push the gas down then let the clutch out, do it the other way arround, that will make the clutch last a lot longer. Im pretty sure you dont need a new clutch, as show signs of death usualy they slip then engine will rev hard but you wont gain a lot of speed. As well as The contour's clutch is really durable, most of the people on this site still have the origional clutch and the other ammount that doesnt has had to replaced it at abotu 160K-170K miles. If after you try my shift method you still have bucking when letting out the clutch, take it to a transmission shop and have your transmission fluid level checked, and find out if you need to have it changed. If you change it, get the fluid part number from here
