#995898 07/04/04 12:25 PM
Mark 77 Offline OP
Can anyone tell me how to change the lights behind the AC/heater controls?
Mark, Contour GL 2,0 ATX, -98
#995899 07/04/04 03:48 PM
Pre98:
Use a Straight Screw driver and pry behind the hvac trim (ac/heater trim). There are four clips that hold this piece on.
Post97:
There is four screws under the Radio, Use a Philips Screw driver to remove them, then the hvac trim should remove fairly easily, might require a bit of prying at the top, and pulling down on the bottom half in oder to get the stereo rest out.
Final Steps:
Once you remove it, unclip the dimmer switch. now user a Philips Screw driver to remove the screws holding the hvac panel in. The bulbs are now accessible, remove the wire harnesses to get to them eaiser. There are two bulbs.
Hopes this helps.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
#995900 07/04/04 07:39 PM
Mark 77 Offline OP
Thanks, but. Mine is a 98, newer version. There are screwes under there i tried to remove but it didn't help, can't get the panel off.
#995901 07/05/04 10:05 PM
I also have a 98 and if you take the screws off then there are the 4 clips 3 on the top one on the side. It takes some yanked to get it off. I have taken mine off twice and one clip is broken from it so you might have to get some new clips but all you have to do is give it a little encouragement and it will pop out.
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#995902 07/06/04 02:48 AM
is changing bulbs all that is required to change the color in door switches, gueges ect as well...?
