hi
as you can see from photo while the LIm has larger ports the SVT/ST200 UIM does not and you have a large step right round
now i know the butterflys and shaft in the LIM will cause a bit of an obstruction
next thing what results might there be if the ports in the UIM are opened out a bit to match the UIM port size a bit more
http://www.imagestation.com/picture/sraid125/p6fc493c34d1efadb780ef3da91ae97a2/f8094bff.jpg.orig.jpg
art
flow more air, more air more power
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
Did you mean the UIM opened up to match the LIM ?? If so, we call that "port matching" around here. The results - a smoother transition from UIM to LIM theoreticly reducing the possibilities of eddies and air swirling where it shouldnt be swirling. (that's good)
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
hi derk
thanks yes that is what i meant
so opening out the smaller UIM ports to match the lower UIM 34/35 ports is a good thing
art
Yup, it's a good thing.
