My wife's 95 is overheating. In October '03 we overheated and blew the head gasket. The head was milled flat and reinstalled along with a new pump, thermostat, overflow cap, and timing belt. Additionally, I have replaced the radiator fan motor in the last year. Since the repair, it has inconsistantly run hot. The guage nearly went to the red last weekend, (past L), and I saw steam coming from the cap on the overflow tank. I've had to refill the overflow tank everyday since, but I can't see a leak. Can that much coolant boil out of the cap? Also, the only time I notice the fan coming on is when the A/C is used. It may be coming on at other times, but I haven't observed it. I haven't noticed it coming on when the car's off either, even as steam comes from the cap. The shop that did the work admitted that the car was runnig hot, but said that the temperature measured fine at the thermostat housing. The tech suggested installing a new radiator and additionally suggested that the fan resistor might be bad,(what is this resistor thing? I have found nothing on it). My pal at NAPA got me a radiator and all new hoses at cost. Before I use these expensive parts, give me some suggestions on what to look for besides the thermostat being bad.
