Posts: 652 |
If its overpowering them is there anything I can do to stop this? Should I just take the 2 15's out and put one of the 15's in single box and just run one of them? Or is there something else I can do?
Champagne 1995 Ford Contour LX R.I.P. - 7/11/06
V6 2.5L 24v DOHC
Oversized System
Posts: 8,301 |
If you have the bass on the deck or amp turned up, I would turn it down until it stops popping. Using one will still be overpowered. By my experience, I would not overpower a Punch sub by very much at all.
IMO, you should be fine just by turning down any bass boost you might have up.
-Ken V.
psycho_bass@hotmail.com
Posts: 652 |
I was listening to my system this morning before work and after work today and I have not heard any poping at all. One of my friends said that they probably just need to be broken in. Could this be the reason they were poping? If this poping problem comes back I guess I can rule out breaking them in. Thanks for all the help.
V6 2.5L 24v DOHC
Oversized System
Posts: 54 |
just out of curiosity do you lights dim with the bass? my subs are popping when I turn them up and I thought it was a problem with the subs but then I noticed that the lights on the amp were dimming with the bass and when it hit hard the amp was cutting off! thats what is causing the popping sound. I'm trying to upgrade my ground and power wires to see if that fixes it, but I dont know...
Posts: 951 |
I had a question similar.... my subs do that sometimes, but its a hard rumble. my front speakers, which are externally amplified, pops when i turn the HU off. is this because the wire that powers the 6x8s isnt fused? the 0 gauge wire up front is fused, then to the distribution block and out of it the 8 gauge wire isnt fused. the 4 gauge wire for the sub amp is fused
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 652 |
Originally posted by Tj78492: just out of curiosity do you lights dim with the bass? my subs are popping when I turn them up and I thought it was a problem with the subs but then I noticed that the lights on the amp were dimming with the bass and when it hit hard the amp was cutting off! thats what is causing the popping sound. I'm trying to upgrade my ground and power wires to see if that fixes it, but I dont know...
Hey, I searched and found a very old post of mine. I am having the problem above with my system. I have the same subs, amp, etc. My subs pop when I have on my headlights and I have my volume turned way up. When the lights are off this doesn't happen. I have not checked the amps yet but I can imagine that they would be cutting out, that makes sense. The subs will pop, no sub reaction for a second or two, and then back to normal. Anyone know how I can get this fixed? I am guessing upgrading some wiring but I am not sure what. Thanks In Advance!
V6 2.5L 24v DOHC
Oversized System
Posts: 3,076 |
Originally posted by GregDawg: These are the P1 Punches
heres a good place to look.. Stage I's are notorius for seperating the cone from the sorround..
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 652 |
Originally posted by CarpePoon: Originally posted by GregDawg: These are the P1 Punches
I notice one of my 15's is making a stranger than normal noise but still bumps. Would this problem with the sub be causing the amps to cut out though? I wouldn't think it would.
V6 2.5L 24v DOHC
Oversized System
Posts: 652 |
Anyone out there? I'ma try to kick this post in the rear. Can it be an issue of battery power? My car strangely didn't start one day last week for no apparent reason. Jumped it and it was fine. The susbs seem to pop more now after that has happened. I know it sounds strange and over dramatic but could it be an alternator or could it be the wiring? I know someone here has to know.
V6 2.5L 24v DOHC
Oversized System
Posts: 1,456 |
With the car running and system and other accessories and lights OFF, try measuring the battery voltage, should be above 14. Your battery could just be weak, so there is no reserve capacity in the car's electrical system. You could have loose or corroded connections at the battery or amp, snug them up. Check amp ground wire too. Push lightly on each woofer cone and see if they move smoothly without scrape noises. A large capacitor might help, but is a "tweak" for a system that has good wiring.
