Posts: 54 |
so what do you have to do to get to the alt to batt wire? and also how do you remove the airbox? while we're at it what is the air box?
Posts: 4,639 |
the air box is the air intake.
Hugo AIM:omegazodiac
Posts: 4,639 |
my understanding is just accessing the alt to run the wire from one side of the engine where the alt is to the other side where the batt is. though i believe u dont want to actually replace the wire cuz of it being connected to a regulator or some crap so simply add an o-ring connector to whatever gauge power wire u use and add this to the alts pos connector then simply run this wire in unison to the battery
Posts: 951 |
I got the Haynes manual, I think you can replace it. We'll see. Should I use 0 gauge wire for about 1200wrms?
1999 SE White
AVH-P6500DVD
Infinity Reference 6500CS
Pioneer 5x7s
Punch 360a2
Punch 500a2
Adire Tempest in a custom sealed 3.4cuft box
Modded Xbox
Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
Posts: 4,639 |
i would use 0gauge. in fact, i am using 0gauge
Posts: 6,280 |
0ga will do ya fine.
Posts: 951 |
That stuff is just so much harder to bend.... I have 3 feet clear 0ga now, how much more would i need? and are set screw terminalts ok?
1999 SE White
AVH-P6500DVD
Pioneer 5x7s
Punch 360a2
Punch 500a2
Modded Xbox
Posts: 6,280 |
Usually the crimp style terminals are easier to use because the loop end is thinner, so you can use a shorter bolt and they won't stick out as far. I don't know about the lentgh though.
Zippy Zetec on his last legs.
Posts: 1,262 |
Originally posted by ChattavegasSE: What are the "Big 3"? Last I heard of the Big 3 (USA, Great Britain, and Russia) was WWII. I hope it's not WW3 and I slept through it!
you did, it happened when you were sick a few weeks ago...didnt last long, we won!
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 3,264 |
Originally posted by hmouta: the big 3 is battery to chassis ground, chassis to engine/tranny ground, and alt to battery pos
No dimming lights so far. The Focus uses pretty much the same engine, transmission and alternator as the Contours. It worked just as well in my duratec Contour. Remember, you are augmenting the factory wires, not replacing them.
