Actually, you were completely wrong about anything to do with the fuel management. I checked all of the things you mentioned. I even managed to disassemble enough to check the fuel rails and injectors themselves. Everything was fine. But my brother (who had a 97 GL contour) suggested that it might be the CAT. Also, after listening to his suggestions i came to this conclusion also. Since my contour is a 99, the CAT is still covered under warranty. I took my contour a local Ford dealership and they are now replacing the CAT, the vaccum hoses, the exhaust and intake manifolds, and the muffler free of charge, parts or labor. This is because the CAT went out prematurely and caused excessive wear on all these other parts. If anyone else is experiencing a loss of power all the time or during heavy acceleration i would suggest having this checked. If its a 99 or newer it will be free anyway.
