#986927 06/22/04 03:28 PM
hi
just awaiting svt UIM,LIM, throttle body, etc which i have bought from a forum member
will be fitting to a 1998 170hp duratec engine and have a couple of questions
will i be able to use my own injectors and just transfer them to the svt LIM
will need an SVT throttle cable bracket , but need to know if anyone has the part number for a throttle cable as mine will not fit
art
#986928 06/22/04 04:50 PM
yes your injectors will fit and replace the o-rings when you do the swap
the part number for the bracket is under the how-to on installing a SVT tb on a non SVT car
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#986929 06/23/04 03:43 AM
the throttlebody is pretty simple. you will need a new cable , throttle position sensor, svt t.b. bracket but the pre98 ones apear the same but im not sure, you will also want to get a svt t.b. accordian tube since the regular one is real small and hard to fit over it. it was a pain to make it fit over it. just put the afm on last to make it a bit simpler. attach the accordian tube at teh bottom fist than use a screw driver to make it fit over the top. i aslo swapped my lim for a svt one and my uim for a standard one that i cleaned out and optimized the throttle mouth. but ive been missing on the 6th cylinder ever since on my 98 s.e. i think i have a bad or clogged injector. also be real carefull with the uim bolts they will snap if you tighten them down too much i learned that the hard way.
98 contour s.e. sport mtx http://www.cardomain.com/memberpage/503352 all mods shown on page
