Posts: 331 |
What do u guys think about building a system where outside air from under the car goes up into the intake
99 Zetec Atx Se
17's w/yoko H4 rubber
Green and Black interior
CTA + header + big pipes = very loud
89 Mustang LX (stock for now)
Posts: 1,444 |
maybe i'm not fully understanding, but are you just thinking of a true cold air intake where the filter is down by the ground?
Posts: 331 |
Not acctually moving the filter, but adding tubing from the front up to the filter
99 Zetec Atx Se
Posts: 8,143 |
you mean tubing running from the top of the filter to a fog light hole or thru the fender?
CEG road warrior
CEG road warrior
Posts: 17,248 |
In reality it is not going to give you much power.....you would need to make a true CAI.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 331 |
Originally posted by ZetecNinja: you mean tubing running from the top of the filter to a fog light hole or thru the fender?
Yes
99 Zetec Atx Se
Posts: 331 |
Originally posted by LoCoZ: In reality it is not going to give you much power.....you would need to make a true CAI.
Anything is better than what I have and what exactly is a true CAI
99 Zetec Atx Se
Posts: 8,143 |
Originally posted by Monstour: Originally posted by LoCoZ: In reality it is not going to give you much power.....you would need to make a true CAI.
Posts: 242 |
Originally posted by ZetecNinja: Originally posted by Monstour: Originally posted by LoCoZ: In reality it is not going to give you much power.....you would need to make a true CAI.
that engine bay looks great,.. except, you REALLY need to do something about the chocolate pudding you have in your overflow tank. get a professional flush of you system done. or at least some prestone do it yourself flush or something. and use distilled bottled water with the coolant when refilling system, not tap.
really like the cam cover by the way. machine polished right?
Posts: 331 |
So where is the filter at in this picture?
99 Zetec Atx Se
