9
Ok guys I noticed I forgot to plug in a connector when cleaning my upper and lower intake. Itâ??s located on the same loom as the idle air pass valve. It comes from the same harness as the rear bank injector harness, then continues over near the EGR and IAP. Where does it go? Thank you so much for helping.
edit: 99 svt btw
99 SVT Contour under 43k miles - For sale!!! pm for info. 89 Taurus SHO 90k miles next....STI swaped Impreza
H
H
Wire colors would help, but try this: connector id
9
the wires are white and brown each with a green stipe.
that link didn't really help, but thanks for trying.
H
H
ECT sensor; below throttle body, points towards rear of car.
9
sorry but what is the ECT? ill take a look tommorrow when its light out. thanks
H
H
Sorry, ECT = Engine Coolant Temperature sensor. Different than temperature gauge sender unit which has only one wire and points towards driver's side of car.
9
horseydug you are the man thanks. it was the ect
