#983047 06/17/04 09:06 PM
I just recently got my stique up and running and well it runs find other then the added knock from what i have no idea. But it keeps dying on me every time i get off the highway at an exit. It does just fine though town. But it dies when i get off the highway before i even coem to a stop. it does this no matter if i put it in neutral and brak to a stop or leave it in gear! What could be cuasing this?
97 Mystquie GS - I4 ATX died at 168K 94 Pontiac Crap AM SE - 2.3L I4 5spd 2002 Mazda Protege5 - 2.0L ATX
#983048 06/17/04 09:39 PM
IAC? Or perhaps a vacuum leak?
#983049 06/17/04 11:26 PM
nope no vac leak. I just got off the phoen with my mech and he said my throttle body was so black that he had to clean it a little to get it to open. So he thinks cleanign that and the maf will fix it. After all the car did set for 8 months with the throttle body off the car!
#983050 06/18/04 04:42 PM
Static timing set right? I imagine if it was one tooth (about ten degrees) it could still run but not very well.
#983051 06/19/04 02:22 AM
Have you checked you PCV and related hoses??
____________________ 96 GL Sport 2.0L Zetec ATX Custom Focus Intake MSD Blaster DIS Coil ____________________
#983052 06/20/04 02:33 PM
R_G Offline
Also, check on TPS and reset your comp (fuses 4 and 11 in your engine bay power distribution box).
#983053 06/21/04 02:27 PM
Ive cleaned out the throttle body with a tooth brush and some carb cleaner. Before i did that i unpluged the coil pack and removed spark plugs to prevent hydro locking the engine. Their was also a 7.5 amp blown fuse in my fuse panel by the stearing wheel. I replaced that... the car seems to idle a little better but I still have yet to test it on the highway and see if it still dies on me when exiting.
#983054 06/22/04 12:17 AM
Zippy Zetec on his last legs.
could it be an EGR valve?
Regards, Cole. Relegating to troll status sometime this week. New Whip: 1990 Lexus ES250. Old Hotness: 1995 GL MTX Zetec *IN TRIAGE* "I had a little friend once, but it dont move no more... "
#983055 06/22/04 01:51 AM
nope just one really really dirty throttle body. I got to test it out on the way to work and it didnt die. Came close but I didnt really clean it to the best of my abilities either... The little bit I did clean seemed to help a ton!
