Posts: 242 |
I searched and never really got a definite answer on this. I want to install indiglo gauges and I found a 98 cluster that already had some installed. Will it work on my 95?
Posts: 3,395 |
Most likily: No, because the 95 Ford Contour uses a cable drivin Speedometer, 98+ im sure uses the electronic signal
Posts: 242 |
I seen where someone hooked up a 96 cluster on a 95. What's the difference between a 98 and 96? They looke the same to me.
Posts: 4,294 |
they are actually a lot different, to the untrained eye, a lot of the lights are in different positions, the wiring is less complicated on the newer gauges, and only a thousand or so 95 contours/mystiques had cable, open your gauges up, by doing a few simple tasks. If you already have a new set uninstalling the gauges is quite simple. look for a manufactering date on the back, if its from January 1995 on, you don't have cable, (you should also see it if you do) if its before jan 95, you probably got cable. And no one try to chime in, the first tours were made before 95.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
I am Canuckian
I am Canuckian
Posts: 4,168 |
If your tenth's marker on the odometer is in yellow. You have a cable driven speedo. As for the mixing of the 2 guages. I'm not sure if they will work but one of the main differences I have seen and I'm not sure what year it starts is. There is a Foglight indicator on the Dash. I'm pretty sure it started after 98. Otherwise it is on a trim peice of the dash in the pre 98's. Hope this helps some.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 4,294 |
people have put svt gauges in a 95 se, it does work. you will be fine.
95 SES Sold
99 SE Sport Sold
Posts: 3,395 |
Originally posted by mbb41: If your tenth's marker on the odometer is in yellow. You have a cable driven speedo. As for the mixing of the 2 guages. I'm not sure if they will work but one of the main differences I have seen and I'm not sure what year it starts is. There is a Foglight indicator on the Dash. I'm pretty sure it started after 98. Otherwise it is on a trim peice of the dash in the pre 98's. Hope this helps some.
I have cable drivin... My 10th digit is black...
Posts: 242 |
So all I do is match the plugs up and it will work just fine? By the way mine does have a cable.
Posts: 4,294 |
Originally posted by jon_mason14: So all I do is match the plugs up and it will work just fine? By the way mine does have a cable.
then it won't work.
95 SES Sold
99 SE Sport Sold
I am Canuckian
I am Canuckian
Posts: 4,168 |
Originally posted by ContourKev: Originally posted by mbb41: If your tenth's marker on the odometer is in yellow. You have a cable driven speedo. As for the mixing of the 2 guages. I'm not sure if they will work but one of the main differences I have seen and I'm not sure what year it starts is. There is a Foglight indicator on the Dash. I'm pretty sure it started after 98. Otherwise it is on a trim peice of the dash in the pre 98's. Hope this helps some.
Really? Well my bad then. Every one I have seen in the wrecking yard with yellow tenths has been cable and visa versa. Either way ignore what I said to be fact as I am misguided.
SVT exhaust
SVT UIM
Optimized se TB.
