ktung Offline OP
Hey guys, this thing is bothering the hell out of me. Under light braking, I hear a clicking sound coming from my driver side front tire. I jacked up the car, took off the tire and rotated the driver side front rotor. Nothing. I did it with the brake slightly applied, still nothing. But I ended up with a nasty little blood filled bump on my hand because it got caught in the caliper. Any insight on this is greatly appreciated. Thanks.
98 Mystique LS
112,000 Miles
Zippy Zetec on his last legs.
screw in your tire?
Regards, Cole. Relegating to troll status sometime this week. New Whip: 1990 Lexus ES250. Old Hotness: 1995 GL MTX Zetec *IN TRIAGE* "I had a little friend once, but it dont move no more... "
No life but CEG
No life but CEG
Sand or heavy dust in the caliper.
R.I.P: 95 Tour LX working on getting SVT Power! SELLING 3L LIM AND UIM W/ TB!!! PM ME....
my first thought would be either something in the tire or poss the cv joint. do you notice it while doing a slow roll down the street w/o light braking?
ktung Offline OP
the wierd thing is that it only clicks when i lightly brake. this is often becuase i'm in the city. When i'm on the highway, braking slightly harder, i don't notice a clicking. I'll check the caliper.
EDIT Just found out from the previous owner, my sister, that the driver side tire has been through a lot. It shakes a lot while driving. Do you think that is it or do you think that they are unrelated?
definatly related, start TS'ing suspension compnenets now. start with the CV joints.
ktung Offline OP
Will do. Thanks guys.
N
N
I have it too, but from my rear wheel. It goes away when the pedal is pressed tighter.
I doubt it's a CV joint or bearing. It's in your caliper. You might grease the caliper slider pins (bolts?) and clean any brakedust crud you see and see if that helps.
