mozha Offline OP
My orange air bag light on the dash near the speedo flashes a sequence of 3 times then 2 times. Seems like a specific trouble code but I am not familiar with this. Sometimes it doesn't flash at all...rather intermittently, but for the most part it's always flashing.
Any help would be greatly appreciated.
Ian
H
H
Always good to review FAQ section air bag codes .
Bad connection around steering column indicated. Any recent work in that area?
mozha Offline OP
thanks for the help...much appreciated
F
F
Help. I've got the same 3-2 pattern. I've torn the whole steering column apart, checked the clockspring harness for continuity (all OK), could it be the airbag?
mozha Offline OP
I'm not sure if it's a 3-2 or a 2-3 code I have or what...I'll have to check it out more closely.
My problem seemed to coincide with a short on my Hi-beams, gear shift safety lockout, signal lights and blower fan circuit...fixed that, but airbag still a problem.
I will keep at it and let you know in time what I come up with. I think there might be a special module somewhere thats screwed up maybe....more later.
Ian
Z
Z
I'm pretty sure I had that code when my battery started to go bad. Have you had any battery problems lately? How old is your battery? If its more than 6 years you may want to think about replacing it. Its better than getting stranded at some point
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
F
F
My battery is weak . I'll look into that one.
mozha Offline OP
My battery is new...I'll keep looking for problem...thanks
