Posts: 256 |
So im putting in my amp and subs today and i want to know where is the best place to run the power through the firewall?
Zach
Black '98 SVT Contour Clear headlights Door ding guards removed 15% tint all around 5 in. LCD and DVD player K&N Intake
When a cat is dropped, it always lands on its feet. When toast is dropped, it always lands butter-side-down. I propose to strap buttered toast to the cat's feet, butter facing up. The two will hover, spinning, inches above the ground. With a giant buttered-toast/cat array, a high-speed monorail could easily link New York with Chicago.
Posts: 123 |
Check around the steering column. I have yet to try this, but there are other people who are running 4 guage through there. Hope that helps!
2001 Mustang GT Old car:98 SVT #750
Posts: 9,178 |
If you have an auto there is a tear shaped grommet right in front of the driver seat and that is where I ran mine.
Posts: 22 |
I ran mine through a huge wire bundle by the steering shaft. Stuck a coat hanger through from the engine bay and used that to pull the wire back through. Just make sure you put some grease on it - makes it much easier to pull through.
Silver 1999 SVT #1938 of 2760
Posts: 256 |
I keep trying with no luck but i'll keep looking and trying, thanks for the help
Zach
Posts: 256 |
Zach
Posts: 338 |
hey scroll down to the bottom of this page: http://area413.tripod.com/stuff.html it shows where I got through the firewall
Posts: 256 |
So you must Drill through the firewall from the inside of the car?? Its not a clear picture. What size drill bit did you use? Where exactly did you drill?
Posts: 108 |
Ok get under the hood of your car. Now look at the firewall directly in front of the drivers seat. You should see a black cap in the shape of a tear. This cap pops off. Poke a hole in it and in the insulation behind it. Run your wire through and your set!
Matt-- 1999 Contour SE
Posts: 256 |
Got it thanks, I just had to move the insulation out of the way. Thanks for all the help.
Zach
