Posts: 2,728 |
I posted about it a while ago and people said brakes, so I replaced my front pads and rotors. I'm still getting the same thing though. It seemed like it wasn't as bad right after I got the new brakes on, but now it's just as bad as before. When slowing down, espicially at higher speeds (expressway), the front end shakes real bad. When you push the brake harder though nothing happens. Any ideas?
'03 SRT-4
50 trim turbo + support
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 2,728 |
Oh todras, Mr. Helpful you. haha, I'll look into it.
'03 SRT-4
Posts: 1,459 |
Perhaps your caliper pins are sticking.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 499 |
Are the calliper pins "lubeable?" 2 of my callipers seem to be sticking a little, I wonder if lubbing the pins would help this?
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Posts: 2,728 |
Are caliper pins something you can just buy and replace? The shaking is pretty bad on the expressway, at least to the point where I'm not comfortable driving it.
'03 SRT-4
Posts: 25 |
Mine does the same thing  Hope you find the solution. -Josh
Posts: 2,725 |
Originally posted by RyeLou: Are caliper pins something you can just buy and replace? The shaking is pretty bad on the expressway, at least to the point where I'm not comfortable driving it.
Unless you strip them when removing them why would you replace them. You need to lubricate them though, using slide pin grease. Cost like $1 a packet at Autozone. Make sure to clean then off first, then lube them.
My car shakes to when braking still havent found the problem though.
Posts: 713 |
-Josh
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph
with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
Posts: 753 |
Mine does the same thing and I'm starting to think it's the ball joints.
Dueling Duratecs
'95 SE V6 MTX 0 Mods
'04 Mazda6 S Wagon
'03 Kawasaki Z1000
But thus do I counsel you, my friends: distrust all in whom the impulse to punish is powerful!
Friedrich Nietzsche
