Looks like I missed CEGs group buy for the obd-2 software/cable. Do you guys know if there is another one going on somewhere now?
I'd appreciate any help,
Krisztian
'99 SVT (black)
Well I wasn't running the Group Buy, however I do carry the following OBD-II Diagnostics Scanner:
Hellion OBD-II
The Hellion OBD-II handheld interfaces with any 1996 - current model vehicle sold in the U.S. The OBD-II standard format allows the Hellion to retrieve trouble codes, oxygen sensor test, continuous misfire detection, fuel system and component monitoring, freeze frame data as well as real time data.
The Hellion supports all the required protocols: SAE J185 VPW (variable pulse width modulation) - GM and some Japanese vehicles, SAE J1850 PWM (pulse width modulation) - Ford vehicles made in the U.S. and abroad, ISO 0141=2 Most European and Asian made vehicles and Keyword 2000.
This ergonomically designed tool has been engineered specifically with the user in mind. Extreme attention was applied to the ease of maneuverability within the menus utilizing as few keys and keystrokes as possible. Attention to ergonomic fit is clearly apparent in the comfortable grip and ease of operation of the membrane keypad.
The application program is internally stored in a flash memory, which can be updated through a dedicated site on the Internet via a PC using a standard DB9 RS-232 serial cable.
PM me if your intersted. Thanks
RamMotorsports Lowest prices on SPEC Clutches and Flywheels
Moderated by  1314_dup1
