#77710 06/21/01 12:03 AM
1
1
I have four 12" eclipse single voice coils and I want to bridge them together so that I only have one -and one + connnected to the amp.(Only one wire going into each of the 2 amp terminals. It is a rockford 500.2 amp). I had it like this once and it hauled some serious a$$. I disconneced them all to carpet my box and wired them back up, but it wasnt as loud anymore.
From the back of the box this is what i have.
AMP
If it is possible I woud like to bridge the outer subs together, b/c they are older and it was louder before when i had those to paired up.Thanks for you time guys.
#77711 06/21/01 12:26 AM
AMP
Are the VCs 4 ohm? If so, bridge the amp run 2 of the speakers in series, then parallel the pairs. It will give you a 4 ohm mono load which will get the maximum power out of your amp.
Moderated by  dnewma04_dup1
