Jason C,
I would start by checking the front sway bar bushings and the linkages that hold that attach the sway bar to the front struts. Not sure if the SVT is setup the same way, but on my SE it was pretty easy to replace these. Very inexpensive too. From reading these posts, it seems to be a very common problem. Heck, I am a victim of it.
Might want to check the rear sway bar bushings too. Here is a link to the "Common Problem":
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=17Other possible items to check are the ball joints, tie rods, and sruts. Start with the easy things first.
Run a search on the site, and you will find posts about this in detail. Good luck.
Radioactive.
