PTAaron Offline OP
I just installed a Sony head unit and ran into a minor snag... there is no dark blue (antenna power) wire. There is an "Amplifier Turn On Switch" (blue/white) wire - which is a good thing... In the directions for the wiring adapter kit it says if you have no amplifier wire you can use the antenna wire to trigger it... so my question is can I splice the Antenna wire(blue) into the Amplifier Turn On wire(blue/white) from my head unit and get the right result (antenna going up when the stereo is on)??
Seems to me that it should work out just fine - but I wanted to run it by the experts...
-Aaron 1999 Contour SVT #2553/2760 Order protein powder from www.trueprotein.com and use AAL229 to get 5% off!
some new HU's are only giving amp turn on wires. very stupid but power antennaes are becoming rarer nowadays. The voltage for the amp turn on wire and the power antenna are usually different but i have heard of hooking up the power antenna directly to the battery so you should be ok with just hooking up the amp turn on lead to the power antenna
05 Chevy Colorado z71 4x4 *for sale* 97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked) 97 Honda Accord 4 door 03 Eclipse GS
Yeah, you will be ok. I have done the same thing several times.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
PTAaron Offline OP
Thanks for the quick replies guys - I may even have time to do that before I leave for work this morning
Moderated by  dnewma04_dup1
