#77620 06/19/01 07:48 PM
E
Evil1 Offline OP
E
do you guys think that 2 15's is to much
for our contours. i am think about getting
2x1000rms 15. does anyone have any 15's in a contour if so how do you like them
'98 Contour se V6 auto
Blue headlight,foglights, and green backup light and green underbody neon
Clarion Pro Audio headunit
6x8 Audiobahn up front
6x8 Infinity Kappa in rear
all new system coming soon
slimshorty42@hotmail.com
#77621 06/19/01 07:54 PM
That depends a lot on what you are looking for. Honkeytonk has a 15" Lambda sub that he is installing for a SQ oriented system. 2 15s could provide huge bass and good quality. You may have a hard timing matching up satellites to them.
#77622 06/19/01 10:20 PM
qdog, how is your electrical system handling all of this power? Do you have an upgraded alternator or battery or do you have a cap? If you do what brands do you have? Thanks
#77623 06/20/01 08:04 AM
In the setup I have now, I will have one 15" LA. I'm going pure SQ with my system. At the moment, I can't find any sound that causes distortion, even at full volume. I've tried pipe organs, pianos, different reed instruments, nothing even phases it, although the higher keys on the piano sound shrill, so I need to adjust the tweeters. My current sub is my systems big weakness, which is why I'm getting the LA. I hope to have every frequency covered. You can cram as many 15's into the car as you want. As long as you adjust it properly, you can have very good sound. You just need to match all the parts up properly. You can't have a high class amplifier running factory speakers, it won't sound right. You also don't want the factory amp running a $500 set of components, they require more power to optimize thier performance. So basically my answer is the same as Dave's. Except that in my version, you should poop on your stereo...
#77624 06/20/01 01:18 PM
That's probably the most important advice he could have given you. I can't believe I didn't mention that.
#77625 06/20/01 03:08 PM
Yes Dave, you appear to be slipping... RIGHT INTO MY TRAP!!!... What? I didn't say anything about poison turkey...
Moderated by  dnewma04_dup1
