#77535 06/17/01 03:34 AM
does anyone know how to hook up a 1 fraud cap
i have a p.gold 1 fraud cap and don't know how to hook it up?
can anyone give me instructions? thanks frown
95 contour se blue
dual exhaust
rims
more mods to come
everyone needs to believe in something i believe i need another beer!
#77536 06/17/01 09:31 AM
Here's what to do:
Run the power cable from the battery to the amp. Now pick a spot where you want the cap to go (It should be as close as possible to either the amp or distribution block. Cut the power cable in the chosen spot and put connectors on the ends.
Hook the negative to your ground wire. You should ground everything at the same place in the car (I chose the seatbelt reel location)
Hook the positive from the battery to the positive side along with the rest of the wire leading to the amp/distribution block.
MAKE SURE YOU DON'T REVERSE THE POLARITY!!!
Your cap will vent itself and become a paper weight.
#77537 06/17/01 04:20 PM
W
W
I had a fraud cap once... It disabled my ability to decieve folks whenever I wore it. laugh
#77538 06/18/01 10:31 AM
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Get off the stage you suck! laugh
#77539 06/19/01 04:21 AM
W
W
LMAOOOOOOOOOOOOOOOOOOOOOO....
***exits stage left***
:p
Moderated by  dnewma04_dup1
