Posts: 235 |
I just installed the SHO cold-air intake and the engine shut off once when I made a hard left. Other than that the car seems to be running a bit stronger and the exhaust note is louder. Next I am going to mod the y-pipe.
2000 Black CSVT
MagnaFlow resonator, SHO/K&N cold air intake
Posts: 9 |
Hey I wanted to thank everybody on there input for my little problem. I seem to have gotten it fixed by doing the throtle hand procedure.
My next question is how do you clean these damn air filters? I saw there was a couple of people that have had the SHO Shop intake on theres. Should I just replace it with a K&N or can I use there oil and charge kit on the no name one I have.
Bickett34 98 SVT
Posts: 235 |
Did you have any problems with the engine shutting off after installing the SHO intake? Originally posted by bickett34: Hey I wanted to thank everybody on there input for my little problem. I seem to have gotten it fixed by doing the throtle hand procedure.
Bickett34 98 SVT
2000 Black CSVT
Posts: 5,600 |
Bickett34 98 SVT
the intake that came with the sho shop unit is a K&N filter.
Originally posted by andymel: Did you have any problems with the engine shutting off after installing the SHO intake?
an intake would not have any of the side affects that you mention unless you bumped something else loose when istalling it. its just a new airfilter.
check for loose connections around the filter, maybe one got bumped loose.
Black 1998.5 CSVT
Posts: 235 |
Thanks. I figured the same after reading some relevant threads in troubleshooting but it's good to hear this from someone else. I will try this when I get home. Originally posted by KingpinSVT: Originally posted by bickett34: Hey I wanted to thank everybody on there input for my little problem. I seem to have gotten it fixed by doing the throtle hand procedure.
Bickett34 98 SVT
2000 Black CSVT
Posts: 235 |
Finally got this fixed. Turned out to be the battery. It died on me and since I replaced it no more problems like this.
2000 Black CSVT
Posts: 9,872 |
Originally posted by andymel: Finally got this fixed. Turned out to be the battery. It died on me and since I replaced it no more problems like this.
well I'll be a monkeys uncle!!
Posts: 235 |
Don't know if you are trying to be sarcastic but I was just posting in case someone else has a similar problem they can know to check out their battery. Originally posted by Goonz SVT: Originally posted by andymel: Finally got this fixed. Turned out to be the battery. It died on me and since I replaced it no more problems like this.
2000 Black CSVT
Posts: 235 |
Do you enjoy being a jerkoff? Originally posted by Goonz SVT: Originally posted by andymel: Finally got this fixed. Turned out to be the battery. It died on me and since I replaced it no more problems like this.
2000 Black CSVT
