From the Ford Manual:
PCV Valve
2.0L Engine
Removal and Installation
1. Raise vehicle on hoist. Refer to «Section 00-02».
2. Remove three way catalytic converter (TWC) (5E212). Refer to «Section 09-00».
3. Remove oil separator retaining bolts and oil separator and gasket from cylinder block (6010).
4. Remove positive crankcase ventilation valve (PCV valve) (6A666) from oil separator.
5. Inspect positive crankcase ventilation valve and oil separator grommet for deterioration. Replace as necessary.
6. To install, reverse Removal procedures. Tighten oil separator retaining bolts to 8-11 N-m (71-97 lb-in).
The picture did not paste here
. If you want, give me an email address, and I will send it to you.
