I
iougs Offline OP
I
Hi all:
I have mercury mystique 96 with the 2.0L engine ...
I have had CEL dealing with 'lean condition' for quite a while now, like P0171.
Yesterday, I decided to take the car to the dealer hoping that they would replace whatever was causing the problem (MAF sensor most likely) for free since I think it looks like it is a major defect.
Guess not.
The diagnostic is MAF Sensor completely out of range (now, why it does not give a CEL of its own, I don't know). The dealer wants $460 to fix (I imagine diagnostic and maybe labor is to be added), so I said no sireee, I'll pay the diagnostic fee and get out of there.
Now, I am sure I am not the only one with this MAF sensor problem causing lean condition and other little things. There is a technical service bulletin about it so it must be pretty common.
Can you guys recommend a place online where I can get a brand new MAF sensor at a discounted price ? I tried fordpartsonline.com but hey don't seem to carry it.
Thanks a million,
Hugues -
Mercury Mystique 96 2.0L Ford Contour 97 2.0L Mazda RX-7 87 Sport 1.3L The Mazda RX-7 86-88 technical page
I
iougs Offline OP
I
Is the CARDONE rebuilt unit you can can find at parts store ok ?
It's about $100 with a $60 core charge.
Hugues =
H
H
I had PO171 system to lean bank 1 back in Februarry.
You can clean your MAF with non-residue eletric cleaner, and also dont know if you have to but I had to have the downstream O2 sensor replaced as well. The code hasnt came back yet, cost about $120 total part and labor by the way.
I
iougs Offline OP
I
ok, thanks HITMAN ...
I think I'll just spend the 100 bucks for a new one ... Had it been $500, I would reconsider.
Do you need to clean them often ??? Should it be added to the list of things to do every six months ?
At one point I had 4 CEL codes showing up ... all pointing to a lean condition ... I did not complain then since my MPG was fantastic ... unfortunately, I cannot pass Mass inspection with a CEL light showing so I really have to fix it now.
It seems the CEL code P0171 is the first one to show up when I am under load (putting AC on, going uphill, things like that).
IS there a way to test the MAF sensor when out of the vehicle ... Resistance readings to be compared with resistance specs (something like that) ... I don't recall seeing anything on HAYNES manual but maybe FSM has some better info.
Hugues -
H
H
Hugues -
Well mine had never been cleaned at that was at about 60,000 or so when the light came on.
I would just replace your MAF since your going to then and see if that takes care of it.
