#77453 06/14/01 11:44 PM
TonyD Offline OP
Should i use a 2 amp set up for my speakers and sub(s) or not. I was thinking of just getting a 5-6 channel?to run all my speakers and a sub. That would be the easiest right?
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#77454 06/15/01 12:15 AM
E
E
Man I would run two amps
because can bridge them and get more watts
from you amps.
see my signature
'98 Contour se V6 auto
Blue headlight,foglights, and green backup light and green underbody neon
Clarion Pro Audio headunit
6x8 Audiobahn up front
6x8 Infinity Kappa in rear
all new system coming soon
slimshorty42@hotmail.com
#77455 06/15/01 12:16 AM
Yes it would be easier. Its also easier to wire up, since you dont need stuff like distribution blocks, ground blocks, etc for multiple amp setups. Most 5-6 channel amps are bridgeable, too. Ive always had 1 or 2 amps because I couldnt afford the $$ to buy one big 5-6 channel amp at once.
-Ken V.
psycho_bass@hotmail.com
My Car
#77456 06/15/01 03:02 AM
BP Offline
Depends on your budget.
Quality 5-6 channel amps can be steep. I personally run two. 200w Kenwood to doors and 250w MTX to the sub. Total cost about $350. I set the amp for my doors to high pass and the sub amp to low pass, very clean at high volumes.
A friend of mine had a 5 channel amp that was like 1000w (probably about 600rms). Don't know how much he paid but it started acting up after a couple months, would shutdown after about a half hour. In his case the two amp set up would probably have lasted longer than the one because he was pushing it at capacity all the time.
-Brian-
98 SE DTec MTX
#77457 06/15/01 03:09 AM
BP Offline
Originally posted by qdog:
see my signature
Damn qdog that's a sh*t load of power. My ears are jacked up just off of 450w. laugh
-Brian-
98 SE DTec MTX
#77458 06/15/01 05:26 AM
W
W
from you amps.
see my signature
I hate to be the correctional officer here... but... 1200 watt 6x9's?
Boss amp? Putting out 3000 watts? Highly unlikely, even using 'PEAK' measurements.
I have (2) Hifonics Boltar amps rated:
225 x 2 @ 4 ohm rms
425 x 2 @ 2 ohm rms
850 x 1 @ 4 ohm rms (mono bridged)
900 x 1 @ 2 ohm rms (mono bridged)
What model Boss amp is this putting out 3000 watts?
Thw hifonics Colossus only does:
2400 x 1 @ 2 ohms rms (mono bridged)
confused
#77459 06/15/01 06:05 AM
If you have your system cranked up alot and your music has alot of base like rap music, get 2 or 3 amps. If your a coservative old fart like me and listen to classic rock, get a 5 or 6 channel amp. I got a alpine F356, I think, and it works great for me.
Chris
99 SE V6 5sp
#77460 06/15/01 12:22 PM
6-channel amps will work great in most cases but if you are looking for some huge booming bass, go for 2 amps. Generally, the seperate power supplies will help.
I agree with Wrecka about the boss amps. The ratings are largely meaningless.
Moderated by  dnewma04_dup1
