#968151 06/01/04 12:27 AM
Alex532 Offline OP
Does anyone know what the differences are between the I4 and the V6 Manual Transmissions? I need to use an I4 manual with a V6 engine that I have so I need to know if it will work. If there is another thread similar to this, please point me in the right direction, but I have been unable to locate information on this topic so far.
#968152 06/01/04 01:15 AM
I am Canuckian
I am Canuckian
This has been discussed I know and a little more searching may confirm the following.
Aside from internal differences that I beleive are of no great concern and infact can be a bennifit. (bigger final drive.) I seem to recall the Crankcase is different. Just as 95-97's are rod shift vs 98-00 being a cable shift. Hope this helps.
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#968153 06/01/04 02:54 AM
No they are not interchangable. The bell housing has a different pattern and the bell housing is a part of the main case. The input shaft is different (shorter IIRC). Most of the rest of the internals are interchangable. The final drive has a taller ratio and can be installed on the V6 trans, which is common practice when doing 3.0 engine conversion.
