1998 Mystique V6 MTX with 93,901 miles
After getting so close to having my old struts out and having to abort and put everything back on, MY CAR WON'T START! When I turn the key I here the starter motor going but the engine won't. I tried pushing the gas but all I got was white smoke from the exhaust after the car revved a bit but it didn't sound like the engine was really running. Here is some possibly useful info:
When I was pressing the calipers back in I forgot to take the cap off the brake fluid reservoir and fluid leaked out from the lid.
I may have had the car in gear while turning the hub backwards, would this do something bad like reverse compress...?
I had the car up on two jackstands on the front and it was tipped up like that for the better part of two days
Other than that I did only what would be required for the strut/spring howto and replacing the front brakes so I can't see why I would be having this problem. What a disaster! Please tell me there is something stupid and easy-to-fix that I did when messing with the suspension that would be causing this.
