Posts: 165 |
i just put a new amp in and when the radios on there is static on the front speakers, but not when a cds on.
I ran 12 gauge wire to the front door speakers, and i fished around a lil on the passenger side trying to find the damn hole, could i have accidentally damaged the antennae wire ? or is it something to do with the ground wire?
5 speed MTX /KKM Custom Intake /Dynomax Super Turbo /TH Fix /Audi A6 Sidemarkers / Badgeless /Audio:(JBL600.1 amp,Polk Dx Subs, Infinity 6953i 6x9's, Lightning Audio Strike Cap)
Posts: 266 |
first thing I would do is check to see if the radio antanae wire is still completely plugged into the deck. That should solve it, seeing as you only hear it on Radio mode. Go from there.
95 MIDNIGHT RED MTX 2.5L SE TOUR HOMEMADE CAI, FOGS W/ PARKS, F-STONE SH30'S, MYSTERY MOD
Posts: 2,657 |
Definately check your ant. wire connections first. However, don't forget that Radio is inherently noisy, especially with poor reception. Maybe you're talking about a different type of static though, not sure. Good Luck.
Posts: 199 |
Know what, I just saw some sort of connection behind the passenfer side kick plate, and it looked like it was for the antenna. The cable goes up and down, but the connecters were on a 45 degree angle. And it was pretty easy to disconnect. Hope this helps.
BLUE-1999 Contour SE-Zetec-Clear Corner Lights-Nokya 3157 corner bulbs-Kenwood Exelon X815-2-12" Pioneers-4 6x8 3-way pioneers-Cuzo 9006's & 9005's-Glowing Ford Emblem On Decklid-Blue Interior lights-Alarm W/ Remote Starter- Daytime Running Lights-CTA Intake-Winshiel Nozzle Lights-Audi A6 Side Marker Lights-Mesh Grilles (Good Ole Gutter Guard)-Just Added SVT Exaust Thanks For The Idea CEG'ers !!!
Posts: 2,657 |
Originally posted by bk4293: Know what, I just saw some sort of connection behind the passenfer side kick plate, and it looked like it was for the antenna. The cable goes up and down, but the connecters were on a 45 degree angle. And it was pretty easy to disconnect. Hope this helps. Yeah, I know what you're talking about but I don't think that junction has any function. Only benefit would be being able to replace PART of the antenna versus the WHOLE cable.
Posts: 199 |
Is tht connection for the antenna ? If so it's possible he accidently disconnected it. I noticed theres no clips or anything therefore it's very easy just to tap the cable to loosen the connection. Did that make any sense? It's too early for me.
Posts: 165 |
Originally posted by bk4293: The cable goes up and down, but the connecters were on a 45 degree angle. And it was pretty easy to disconnect. Hope this helps. Hey I just checked that out, along with the head unit connection. Both seemed to be fine but may have been a little loose?....I haven't had a chance to go out yet today so we'll see if that fixed it.
Posts: 3,562 |
You may also want to check you connections at the base of the antenna itself. If the base or base ground wire comes loose, some static can entire the reception as well.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 165 |
Originally posted by bnoon: You may also want to check you connections at the base of the antenna itself. If the base or base ground wire comes loose, some static can entire the reception as well. OK static is STILL there when i turn my volume up. I check the antennae base (checked the big wire, but where are the ground wires?)and the radio stations came in crystal clear before I put my new amp in.......any more ideas?
