Page 2 of 2 1 2
F
fazzman Offline OP
F
Ok i went cheap! This what i found, are the settings good? Hey its better then nothing : )
[img]http://albums.photopoint.com/j/View?u=1503669&a=11349275&p=50270371&Sequence=0[/img]
Nick F.
01 Focus ZX3 MTX
borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec
Yes its a zetec, we were here before vtec, so we are not copying!
I
I
looks good enough to me..you shou8ld see the crossovers I have for my components, tune it low and play with the settings to see how it sounds best but Im sure you were going to do that anyway =)
If you want to go cheap why don't you just buy a coil for your crossover? I know it is only a 6db cutoff, but they work fine.
96 Contour SE 2.5
K&N drop in
They are extremely expensive if you want to get anything 100 hz and under. It's much more cost effective to go electronic. Unless you get a really cheap inductor.
I haven't purchased a coil in about five years, but local shops sold them for around $15 for most applications down to 50 Hz.
96 Contour SE 2.5
K&N drop in
Check out parts express . They sell iron core inductors 10mH for about $15. That will get a 4 ohm woofer down to about 65 Hz. They also sell air cores for $25. They have 15mH coils as well.
96 Contour SE 2.5
K&N drop in
Thanks! That pretty much verifies my comments! 25-50 for a 1st order crossover is a little pricey when you can pay a little more and get a higher order crossover and in most cases a configurable design.
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
