I just installed a jbl 1200.1 in my car and I dont think its recieving enough power to be fully used. I have 2 resonant engineering dvc SE 12's that are hooked up to a 1 ohm load for the amp. The gain is barely turned up and I noticed that the light on the amp dims real badly at medium volumes, if I turn it up any higher I think the amp loses power becuase the light on the top goes completely off and the red light flashes, when the bass hits.
It cause a popping sound, and stall in the music which led me to believe it was the subs at first but now I know its the amp. I used an 4 guage kit, and even tried to wire in an extra 4ga ground from the battery to the chassis. Nothing has helped so far. I know its not the amp ground becuase I've redone it numerous times at different locations to make sure.
Its a 97 gl contour, and the interior lights are dimming as well, can any offer some advice?
