#964966 05/27/04 04:31 PM
Mark 77 Offline OP
Is there supposed to be a light underneath the PRND21 on the side of the ATX? If so, mine is dead and it would be great if somebody could tell me if it's hard to change and some tips on how to do it.
Oh and it's a 98 2,0 GL
Mark, Contour GL 2,0 ATX, -98
#964967 05/27/04 07:11 PM
H
H
Yes, there is a light under it.
#964968 05/28/04 12:48 AM
Now that's an answer......
To change the bulb
With a screwdriver, pry the bezel around gear shift you can see the seems.
Next disconnect light housing from the underside of bezel.
Remove the transmission range indicator miniature bulb (13466) from indicator bulb socket and replace it.
Put it back together the way you took it apart.
Easy change.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
#964969 05/28/04 01:36 AM
Your PRND21 never light up!? Wow... im sorry... howd you ever shift at night?
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#964970 05/28/04 01:57 AM
I don't need a light as when I move the shift lever I can tell what gear I'm in.......
#964971 05/28/04 02:08 AM
My shifter feels weird... so i need it...
#964972 05/28/04 05:20 AM
Mark 77 Offline OP
Thanks, i didn't think it would be that easy. I thought you had to take the entire center console apart to reach it.I will try changing it today
#964973 05/28/04 01:40 PM
Mark 77 Offline OP
Thanks for the help!
Ok, now i've changed it, it was very easy indeed. The only thing i wonder is how many Wats it should be? I put a 3W in it and it's very bright, should it only be a 1,5W or what?
